Activity Forums Maxon Cinema 4D Xpresso real-time results from selected nodes “dashboard”. Is it gone?
  • Xpresso real-time results from selected nodes “dashboard”. Is it gone?
    Posted by Steve Bentley on September 27, 2021 at 7:41 pm
    There used to be a little dashboard you could turn on in the xpresso settings (it would appear bottom left), that would show you the output of any port you clicked on of any node. Has that disappeared, or can I just not find it?
    It never needed the animation to update, or for you to stick “result” or “spy” nodes after ports you needed info on.
    Any hints as to where it is?
    Thnx
    Steve Bentley replied 4 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
