Activity Forums Maxon Cinema 4D Xpresso random seed issue
  • Xpresso random seed issue
    Posted by Corrado Carlevaro on August 20, 2019 at 12:05 pm
    Hi everybody,
    in TP preset Standard Emitter there’s a Random node feeded with a random seed taken from PGetData/Random Seed output to randomize e.g. the size of particles. It returns one (not changing with time) random number for each random seed.
    Why is that if I feed the very same (with same settings of course) Random seed with a Constant node it returns different random numbers every frame?!?
    (I’m using a Mograph Matrix as emitter so I need to use the Index number as Random Seed)
    Thank you
    Corrado
    Corrado Carlevaro replied 7 years ago 2 Members · 7 Replies
  • 7 Replies
  • Brian Jones
    August 20, 2019 at 2:22 pm
    what version of C4D? The Random node changed somewhere in there (before 19 certainly) .
  • Corrado Carlevaro
    August 20, 2019 at 5:19 pm
    Version 18, I understand this is the normal functioning of the random node (outputting a different number each frame) so the question is: why is keeping the same number in TP Standard Emitter preset? Usually I use a Noise with the empty Time input port (0)
  • Brian Jones
    August 20, 2019 at 10:39 pm
    Random Mode Free or Time (or is that in R18 yet?)
  • Corrado Carlevaro
    August 21, 2019 at 8:20 am
    AFAIU Mode Free returns a different number each frame and each animation, Mode Time returns a different number each frame but same numbers each animation (starting from Frame 0 you get the same sequence of different numbers)
  • Brian Jones
    August 21, 2019 at 12:30 pm
    That’s as far as my understanding goes too. Are you looking to have each particle have a random size for every frame?
  • Corrado Carlevaro
    August 23, 2019 at 12:41 am
    No, I need a fixed random number for each random seed. Strange is this is as it behaves (and how
    you would expect it) in TP Standard Emitter preset, having a random but fix speed, life, size for each particle etc.
    I like experimenting with tweaked random or noise to drive animations, usually I use a noise node (lately python nodes) with constant time Input to get a fixed random number; different ways to get them in Xpresso I suppose, there’s also one system preset for integers etc.
    But not from the Random node apart in TP preset!
  • Corrado Carlevaro
    August 23, 2019 at 12:20 pm
    Fastest solution with Xpresso Python node (fixed random number):
    import c4d
    import random
    def main():
    global Output
    random.seed(Seed)
    Output = random.random()
