Activity Forums Maxon Cinema 4D Xpresso Question -Repeating Count
  • Xpresso Question -Repeating Count
    Posted by Tony Barone on August 21, 2015 at 1:58 pm
    I’m trying to create an XPresso setup that counts from 0 to 100 and then repeats, over and over again.
    I’d like it ultimately have it connected to an align to spline node to have an object move along the spline, from 0-100%, then start again from 0-100% repeatedly.
    Any help would be greatly appreciated.
    Tony Barone replied 11 years, 1 month ago 3 Members · 3 Replies
  • Adam Trachtenberg
    August 22, 2015 at 8:32 pm
    The easiest way to go about this is to keyframe the align tag’s position parameter. Then select it in the timeline and in the attributes manager, set “After” to “Repeat”. Then specify how many times you want the sequence to repeat.
  • Brian Jones
    August 22, 2015 at 8:59 pm
    in xpresso the answer is Modulo in a Math node or in a Range Mapper but Adam’s right, it’s easier with repeat in the timeline
  • Tony Barone
    August 24, 2015 at 12:37 pm
    Thank you for your help!
    After playing around for a while, I came up with a nice XPResso solution. I’ve attached a screenshot.
    The animations that I plan on using it in are product demonstrations, so I needed something I can use/reuse within larger keyframed animations. I’n not sure if I would have been able to loop just a portion with key framing while having the rest of the animation continue.
    But thank you again for your help.
