Activity Forums Maxon Cinema 4D Xpresso question
  • Xpresso question
    Posted by Rodrigo Diaz on August 21, 2010 at 12:25 am
    Hi, I was wondering how to make sure Xpresso do something, for example an equation, just once and not several times per frame?
    Adam Trachtenberg replied 16 years ago 2 Members · 3 Replies
  • Adam Trachtenberg
    August 21, 2010 at 5:11 pm
    Can you give a more specific example of what you’re trying to do?
  • Rodrigo Diaz
    August 21, 2010 at 5:52 pm
    Xpresso needs to do a calculation (for a varying speed in rollercoaster ride). If the calculation is made more then once per frame the animation will behave incorrctly… Xpresso must give only 1 result for each frame…
    ok?
  • Adam Trachtenberg
    August 21, 2010 at 6:18 pm
    I think the math nodes evaluate once per frame by default.
