Activity Forums Maxon Cinema 4D Xpresso not adding the correct values, always stuck at 100%
  • Xpresso not adding the correct values, always stuck at 100%
    Posted by David Cabestany on November 6, 2014 at 10:03 pm
    I have two different Align to spline tags and I need the second one to be always 5% ahead of the first one, so I made a simple xpresso rig, in which I take the position of the first one add 5 using a math node and then send the output to the position of the second one. But instead of being 45% and 50% for example, the second one is stuck at 100%
    Anyone knows why?
    David Cabestany replied 11 years, 10 months ago 3 Members · 3 Replies
  • Brian Jones
    November 6, 2014 at 10:57 pm
    position (probably anything in %) is passed on as a decimal from 0 – 1, not as a whole number. Simplest thing to do is change your math add to .05
  • Emir Bojorquez
    November 6, 2014 at 11:00 pm
    You are using a real number 5 not the real number of a 5%, in other words 5% is equal to 0.05, you need to conver from porcentage to real number.
    Good Luck
    Imagination is the best tool…
  • David Cabestany
    November 7, 2014 at 4:25 pm
    Thanks a lot guys, that was it.
    Best,
    David.
