Activity Forums Maxon Cinema 4D xpresso help again (align to spline)
  • xpresso help again (align to spline)
    Posted by Olly Bea on August 12, 2009 at 1:28 pm
    Hey all
    I need some help with xpresso if someone could oblige.
    I have 5 cubes and a circular spline. I have attached an align-to-spline tag on each cube using the circular spline. Cube 1 is placed at 10%, cube 2 is placed at 20%, cube 3 is placed at 30% etc… I would like to be able to animate the position percentage of one of the cubes so that they all maintain their spatial relationship.
    How can I do this?
    Many thanks in advance
    Olly
    Olly Bea replied 17 years ago 2 Members · 2 Replies
  • Adam Trachtenberg
    August 12, 2009 at 3:02 pm
    Easiest way to do it:
    Click on the first object’s align tag and then right-click on the offset paramter.
    From the flyout menu, choose Animation>Set Driver.
    Deselect that tag and then shift-click the other align tags.
    Right-click on the offset parameter and choose Animation>Set Driven (relative).
    That’s it.
    Open the Xpresso tag that was created if you want to see what’s going on behind the scenes.
  • Olly Bea
    August 12, 2009 at 3:58 pm
    Amazing thanks, it would have taken a long time to explain that using xpresso.
    You are a genius!
