Activity Forums Maxon Cinema 4D XPresso Gears and Rotation
  • XPresso Gears and Rotation
    Posted by Dan Barter on August 26, 2008 at 2:00 pm
    Hi all,
    I’m sure this is an easy one for some XPresso expert. I’m trying to animate the classic gear 1-gear 2, and can’t figure out how to make gear 2 rotate in the correct, opposite direction as gear 1. I can build the XPresso that turns gear2 when I turn gear 1, but it turns it in the same direction. How do I reverse the direction? I can’t seem to find a node or input to allow me to enter a negative value. Can someone point me in the correct direction, cause the manual reads like stereo instructions and is not very helpful.
    Dan…
    Dan Barter replied 18 years ago 3 Members · 7 Replies
  • 7 Replies
  • Randy Johnson
    August 26, 2008 at 2:32 pm
    math node (multipy a negative)
    a range mapper would also get the job done….you will have to learn that one when you start adding more gears.
    /randy
  • Dan Barter
    August 26, 2008 at 3:35 pm
    Randy,
    The range mapper bumps my gears out of alignment when I set it up. Not sure why that’s happening. I tried the Math.add and changed the node to multiply -1, but it didn’t work. Can you give me a few more details about this, please? I’m a little new with XPresso.
    Dan…
  • Randy Johnson
    August 26, 2008 at 3:58 pm
    I am sorry I was thinking backwards.I posted a using the range mapper.
    I dont have any time right now but if you dont get what you need I can help tomorrow.
    https://www.randyarchy.com/cog.c4d.zip
    /randy
  • Dan Barter
    August 26, 2008 at 8:39 pm
    Ok, I see this now. Seems to be working for me. I’m going to try to add a few more gears now, so hopefully this won’t explode on me. Man, someone needs to write a really good book on XPresso. They’d make a fortune. 🙂
    Thanks Randy
  • Brian Jones
    August 27, 2008 at 4:15 am
    here’s an example I did up on xpresso24 https://www.xpresso24.com/index.php?lang=en&sel=content/download_item&id=35 you might have to register but it’s free and they’ve been good.
  • Randy Johnson
    August 27, 2008 at 5:51 am
    Thanks brian…its always nice to disect somthing that is made as nicely as this.
    /randy
  • Dan Barter
    August 27, 2008 at 2:36 pm
    Ok now, Brian, THAT’S a cool site. Thanks to both you guys for your help. I’m on the right track now.
    Dan…
