Activity › Forums › Maxon Cinema 4D › xpresso and the timeline
  • xpresso and the timeline
    Posted by Matt Collett on April 13, 2009 at 6:13 pm
    Is there a simple way of using xpresso to tell a driven object to imitate a driver object but with a delay.
    so for example if I have a null object (driver) which has a keyframe at the start and a keyframe at frame 20 with a rotation value of 90 degress.
    how can I tell the driven object to do the same rotation but 10 frames later, from frames 10 – 30 rather then 0 – 20.
    thanks in advance, appreciate this is quite probably more complicated than its sounds, so alternatively any pointers to relevant tutorials or resources would be much appreciated.
    I have only been able to find either very basic tutorials (how to add an expression tag) or tutorials which are way beyond my current knowledge.
    many thanks
    matt
    Brian Jones replied 17 years, 5 months ago 2 Members · 1 Reply
  • Brian Jones
    April 13, 2009 at 7:05 pm
    put a Memory Node in between the passed values. The help has a good description of the History Depth and History Level settings in the Memory node – they’re what’s important to get what you need.
