Activity › Forums › Maxon Cinema 4D › Xpression to “wiggle” a value around its timeline animation
  • Xpression to “wiggle” a value around its timeline animation
    Posted by Ryan Paterson on January 7, 2015 at 8:12 pm
    I’m using the Noise node, but how to I hook it up to be a “relative” value, rather than absolute? So my object still follows its timeline animation but with an added degree of randomness… know what I mean?
    Ryan Paterson replied 11 years, 8 months ago 3 Members · 10 Replies
  • 10 Replies
  • Tim Shetz
    January 8, 2015 at 12:03 am
    Could you use the Vibrate tag instead?
    __________
    Tim Shetz
    c4dtraining.com
  • Ryan Paterson
    January 8, 2015 at 12:55 am
    For the intensity of a light? Any ideas on how to do that off the top of your head? I feel like I’ve done something similar in the past but I’m curious as to your thoughts
  • Tim Shetz
    January 8, 2015 at 1:54 am
    From your original post I assumed an object moving along a path and you wanted it to not be so static.
    “So my object still follows its timeline animation but with an added degree of randomness”
    Guess I read too much into it.
    I think using noise in Xpresso is probably the best. So you have a light that animates, but you want to add a little flicker to it?
    __________
    Tim Shetz
    c4dtraining.com
  • Ryan Paterson
    January 8, 2015 at 1:57 am
    yes, precisely
  • Ryan Paterson
    Actually you know what I just figured it out
  • Ryan Paterson
    January 8, 2015 at 1:58 am
    Wait… no I didn’t :\
  • Brian Jones
    January 8, 2015 at 2:23 am
    here’s an xpresso that does what a Vibrate tag does (for position in this case) and the same math (more or less) to ‘vibrate’ the intensity of a light. Volumetric so it’s easier to see…
    8382_vibratekeyframedanim.c4d.zip
  • Tim Shetz
    January 8, 2015 at 2:28 am
    Thanks Brian!
    I was fiddling around and was sort of getting to what you have there, but hadn’t gotten to the clamp quite yet.
    __________
    Tim Shetz
    c4dtraining.com
  • Brian Jones
    January 8, 2015 at 2:35 am
    as long as you want to limit the light to standard values of course… take it out to leave the possibility of negative values or values over 100% and associated ‘bloom’ etc. No problem.
  • Ryan Paterson
    January 8, 2015 at 8:05 pm
    Very nice! The clamp is what I was missing actually. I also didn’t realize the intensity values were a range from 0-1, good to know!
