Activity Forums Avid Media Composer Xpress Pro video does not play in program monitor
  • Xpress Pro video does not play in program monitor
    Posted by Lauralouface on March 21, 2007 at 10:58 pm
    I’m wondering what would cause this:
    When I play video from the timeline in Avid, it plays fine on an external monitor, but not on the monitor within Avid…I’m not very familiar with Avid so I’m probably being too vague, but can anyone help me please? Thanks,
    Laura
    Bouke Vahl replied 19 years, 5 months ago 5 Members · 8 Replies
  • 8 Replies
  • Thegame2737
    March 22, 2007 at 1:23 am
    is the monitor black? or is the video frozen on the screen? doest it skip from freeze to freeze like a strobe looking effect? I’m not sure I’d have any type of anser anyway, but that info might be helpful to the people that know much more than I do.
  • Lauralouface
    March 22, 2007 at 4:15 pm
    The monitor is just black…
    Thanks for replying 🙂
  • Michael Hancock
    March 22, 2007 at 5:46 pm
    Are you on a PC or Mac, what video card are you using, what driver for that video card, and what version of quicktime are you using? What version of Avid are you using (Xpress Pro, Media Composer, version of that flavor, etc…). More info and we’ll get going on fixing your problem.
    In addition, do you have a Mojo, Mojo SDI, Adrenaline box, etc…? Is this just regular video that won’t play, or is it “realtime” effects? Check that you have Render-On-The-Fly turned on–I think it’s under the Clip menu across the top of your screen.
    Let us know!
    Michael.
  • Lauralouface
    March 22, 2007 at 7:17 pm
    Ok, here goes:
    It is just regular video that won’t play, (but render on the fly is checked also) I am using Avid Xxpress v 4.5.1 (Mojo) and the video card is a Matrox Millennium G550, and I just updated the driver…Matrox Graphics vs 5.86.32.0, and Quicktime is version 7.1.5. Also, it is a PC. Whew, hope I got all those!
    Laura
  • Lauralouface
    March 22, 2007 at 8:02 pm
    Ok I’m not blonde – but am feeling like it today. I’m lame and was looking at the source monitor :/ However it doesn’t change the fact that the Composer monitor doesn’t play – you can scrub the timeline and it plays all that, but when you just hit the play button it stays on one frame and plays on the external monitor fine.
    Sorry for being confusing!
  • Thegame2737
    March 22, 2007 at 11:02 pm
    perhaps the computer is bogged down from effects? try rendering if everything is not rendered? That’s a simple fix so there’s a chance you already did that- Also the monitor can not be covered even partially by the timeline, source window, effects pallete, or anything else- however, i’m pretty sure it won’t play in general if that is the case so you wouldn’t see it at all. But I could be wrong. Just a couple of simple things, but sometimes when you look all over the place its that one button thing thats so easy you forget. Hope it is!
  • Dave Schweitzer
    March 23, 2007 at 3:16 am
    Whoops, did someone just recently update quicktime?
    https://www.avid.com/onlineSupport/supportcontent.asp?contentID=10508
  • Bouke Vahl
    March 24, 2007 at 9:42 am
    Check on the Avid site if your graphic card is approaved.
    If not, forget it…
    Bouke
    http://www.videoToolShed.com
    smart tools for video pro’s
