Activity Forums Avid Media Composer Xpress Pro HD and Group editing…
  • Xpress Pro HD and Group editing…
    Posted by Roc Barbanica on February 13, 2006 at 6:52 am
    I used to be able to group clips, put that on the timeline, hit quad split and the four clips appear in source monitor. Then assign M1, M2, M3 and M4 to keys.
    Then hit play and when ever I hit an “Mx” (M1,M2…) key, an edit would appear and the record side would reflect the change. The video would keep playing as well.
    Now, it doesn’t work. What has changed and how can I get it to work again???
    PLEASE HELP!
    Rocky-
    Geo Cohn replied 20 years, 7 months ago 3 Members · 2 Replies
  • Jon Zanone
    February 13, 2006 at 12:15 pm
    I just did this on a AXP 5.2 machine Friday. Here’s my workflow (your milage may vary…)
    -Group the clips
    -Load the grouped clips into the source monitor
    -Lay down the first audio edit
    -Go to Special and select Group Clip Mode
    -The quad split shows up, activating your M1, etc. keys
    -Edit to your hearts content
    HTH,
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Geo Cohn
    February 13, 2006 at 5:24 pm
    What part is not working? The quad split? If you have more than 1 video track, make sure you enable the one with the group in it and disable the others.
    geo.
