Xpress Pro …and Mas pull down menu?
I’ve switched from Adrenaline to Xpress Pro at a new job. In Adrenaline, the Preview moniter and Sequence moniters both had time code/In-Out points ingrained in the top of the window. Is there a way to have the same option in Xpress Pro, rather then pull down the Mas menu each time I want to see what I have marked off?
-Dave
