Activity › Forums › Avid Media Composer › Xpress Power Pak on a laptop
  • Oakmozart
    January 10, 2006 at 4:17 pm
    A certified one. https://www.avid.com/products/xpressStudio/specs.asp Scroll down to the bottom for the laptops. Make sure you have the proper graphics card.
    Other than that, XPro PowerPack should work perfectly on a laptop. If it works with XPro and Xpress Studio Essentials (essentially created for a laptop), logic would dictate that it will work with XPro PowerPack.
    Good luck.
