Activity Forums Maxon Cinema 4D Xpress and Layer Shader
  • Xpress and Layer Shader
    Posted by Adam Trachtenberg on February 16, 2016 at 4:59 am
    To add the Layer Shader to Xpresso, go into the Layer Shader dialogue and then drag the big thumbnail at the top into the Xpresso editor. When you click on the Layer Shader node’s inputs (blue square) you’ll see Shader Properties>Layers>Layer Blend.
    For future reference, if you ever want to keyframe the layer shader, right click on the word “Layers” in the shader properties and then select User Interface>Show Subchannels from the pop-up menu.
    Adam Trachtenberg replied 10 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
