Activity Forums Maxon Cinema 4D Xplode with flat geometry?
  • Xplode with flat geometry?
    Posted by Ryan Paterson on February 18, 2013 at 2:30 am
    Hi, I’m using pFragment to break up some objects but they always break up into boring rectangular polygons, wondering if there’s a way to use Xplode to break up the mesh into more interesting pieces WITHOUT adding the additional geometry that it likes to add to make the pieces into “chunks”. Or if there’s another plugin that will do this that’d be great too. I’m using the Knife tool right now but thinking there must be a better way.
    Ryan Paterson replied 13 years, 6 months ago 2 Members · 4 Replies
  • Brian Jones
    February 18, 2013 at 6:25 am
    Thrausi (by Nitroman) will break a flat plane without adding anything extra
  • Ryan Paterson
    February 19, 2013 at 2:52 am
    Cool, now what if I want to break up say, a cube, but only have the surface divided into new polygons without creating extra geometry, will Thrausi do that?
  • Brian Jones
    February 19, 2013 at 3:48 am
    not directly (I think but I could be wrong) but I would make the cube editable in that case with Separate Surfaces checked to make a null with all the faces as children then select all the children and run Thrausi on them which would break them all.
    If a cube is just an example then Disconnect the parts you need as surfaces then run Mesh/Conversion/Polygon Groups to Objects
  • Ryan Paterson
    February 19, 2013 at 4:28 am
    Good call! Thank you
