Activity › Forums › Maxon Cinema 4D › xparticles, octane, cinema 4d
  • Adam Trachtenberg
    October 13, 2017 at 9:50 pm
    Put an Octane>Object tag on the Trail object, go to the tag’s Hair tab and enable hair rendering.
  • David Rickards
    October 14, 2017 at 12:01 am
    thanks! any idea how i could make this web?
    https://vimeo.com/115449703
    I understand that trails shows the fallow path of the particles. how do i show the line that shows the constraints? when i add trials there is no option. it only has a few options like nearest by distance, cluster, ect….. if any one can show me a project file that would be amazing!!!
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Adam Trachtenberg
    October 14, 2017 at 5:07 pm
    What version of x-particles are you using? I have V3 and the Trail Object gives a “Constraints” option. If your version doesn’t have that you might set your constraints to use particle distance and then use the same distance for your trail connection.
  • David Rickards
    October 14, 2017 at 7:42 pm
    it worked!!!!! thank you so much!!!!!
