Activity › Forums › Maxon Cinema 4D › xParticles – convert particles to polygons
  • xParticles – convert particles to polygons
    Posted by Huig van den Hoofdakker on July 10, 2025 at 11:58 am
    Hi everybody, don’t know if this is the right place for xParticle questions, but its worth the shot.
    I’m a Drone Show designer and work in Cenema 4D with cloners which I can export to costum made software which can read the x,y,z and rgb info and convert that info to make LED drones fly in formation.
    Now I’m trying to make xparticles work within this workflow but it keeps failing. Bassically what I want is to convert the particles to an animated mesh where each particle is one polygon. I allready tried putting a xpGenerator with a polygon in a connect and clone onto the connect. This works fine in Cinema, but the export to the custom software turns out very buggy.
    I tried baking the xpGenerator to Alembic (in multiple ways- just bake the generator, first put it in a connect, first making the polygon editable, set the start frame when all the particles are generated). This sometimes works and it sometimes doesnt. When it works, it’s a good fix. But often it doesnt, so its not reliable for work.
    My question is: Is there a way, other than baking to alembic, to make a an animated mesh from a xParticle simulation where each particle becomes a polygon.
    Kouraib Abdmalek replied 1 year, 2 months ago 2 Members · 1 Reply
  • Kouraib Abdmalek
    July 11, 2025 at 9:22 am
    Hi Huig,
    I don’t know if you tried exporting to alembic format (abc) and then re-importing the file, you will find two objects, delete the second one and then re-export it to the format that suits the target application. You could also use Cloner on Mode Object, then place the particle in the Cloner next to the object channel, then place a MoGraph Cash tag next to the Cloner, then bake. I hope you succeed with one of these two methods.
