Activity Forums Maxon Cinema 4D xp splineflow problems
  • xp splineflow problems
    Posted by Danny Perez-triana on October 24, 2019 at 4:36 pm
    Hey everyone, I’m trying to create a branching object that follows a helix spline.
    I’m using particles 4 in C4D studio R18.
    I’m not having any luck getting the particle to follow the spline.
    Ive messed around with the different controls within xpspline flow, made adjustments within the individual handles and still can’t get the particle to follow the spline. The spline is dragged into the spline tab of xpspline flow as well.
    I don’t know if there’s a simple tag or setting I’m neglecting? Any help with this would really help me get some control over these crazy particles and branches.
    hope everyone is well
    Ignacio
    Danny Perez-triana replied 6 years, 10 months ago 3 Members · 6 Replies
  • Jim Scott
    October 24, 2019 at 5:28 pm
    All that is required is that the spline is dragged into the “Spline” tab, which you have done. Make sure that the emitter is near the beginning of the helix, and that its emission direction basically lines up with the spline, otherwise the particles may not be attracted properly.
    13837_xpsplineflowexample.c4d.zip
  • Brian Jones
    October 24, 2019 at 5:30 pm
    with a helix you’d need more handles that the default, so add some so you have 8 or 10 handles then Redistribute the handles to make them even
  • Danny Perez-triana
    October 24, 2019 at 6:09 pm
    thanks Jim! very nice of you. I tried with a simpler spline (an arc) and evenly spaced out the handles but got this strange effect of it going through first handle then just stopping and not continuing the path. the emitter is placed right at the head/tip of the spline.
    the particles look like they hit a ceiling/stop moving?
    I set the emission to Rate, Emit all frames & full lifespan.
    let me know if you have any thoughts? I appreciate your time.
    hope all is well
    Ignacio
    dip
    October 24, 2019 at 6:11 pm
    that makes sense, thanks! though right now I’m having a hard time getting particles to go through three handles let alone ten, ugh.
    hope all is well
    Danny
    dip
  • Brian Jones
    October 24, 2019 at 6:13 pm
    the spline direction makes a difference so you might have to reverse the spline
    October 24, 2019 at 6:34 pm
    oh geez, that made big difference. I increased the speed and lined the emitter up and angled it accordingly. was a simple fix that I don’t think I would’ve stumbled onto.
    thanks for your time.
    Ignacio
    dip
