Activity Forums Blackmagic Design XP 64 drivers Crashes the computer
  • XP 64 drivers Crashes the computer
    Posted by Manuel Deo on June 27, 2006 at 9:00 am
    somebody is working with the 64 xp drivers???
    My system crash when i install those drivers.
    Maybe, it’s because , i have two os in my computer (XP32 and XP64)?
    If somebody have this problem, i agree to know his point of view
    Thank
    Manuel
    Manuel Deo replied 20 years, 3 months ago 2 Members · 3 Replies
  • Kristian Lam
    June 27, 2006 at 12:49 pm
    Do you have more than 3 gb of RAM in your system?
    Kindly refer to this tech note and see if it’s relevant:
    https://blackmagic-design.com/support/detail.asp?techID=160
    regards
    Kristian Lam
    Blackmagic Design
  • Manuel Deo
    June 27, 2006 at 4:31 pm
    hi Kristian,
    I have more than 3 Gb of ram, i have 4 Gb of DDR 2 400 ECC memory.
    I have read the web adress, and i think i’m too rich of memory.
    I try to take 2 Gb memory off and i try to reinstall decklink drivers.
    Thanks, maybe i find with this adress a lot of answer for a lot of question.
    Manuel
  • Manuel Deo
    June 27, 2006 at 8:23 pm
    hi Kritian,
    I have take off 2 gb memory and the drivers are good.
    I have install those and there is no crashes.
    So when do you think new drivers are ready for system with more than 2 GB memory.
    Thank for the solution at one of my problems.
    I have a second one, i can’t capture the sdi input video with my declink.
    Novideo input with xp 32 and xp 64?
    My deck is a sony dsr 1500 with sdi output input Board. I see the sdi output on my monitor with sdi board, but my decklink says that no video input.
    What do you think about that?
    A system configuration, problem or a decklink card failure??
    I try to install in an other pci-x slot, but the problem stays.
    I appreciate your help and the blackmagic team help
    thank
    MAnuel
