Activity Forums Adobe Premiere Pro XML wrong sequence
  • Peter Garaway
    September 5, 2013 at 9:07 pm
    If your in Premiere Pro CC you have 2 options.
    1. From the Project panel, select the sequence you want to export> File> Export> Final Cut Pro XML
    2. Select the sequence tab in the Timeline panel you want to export (make sure its highlighted), File> Export> Final Cut Pro XML
    That should do it.
    Peter Garaway
    Adobe
    Premiere Pro
  • Stephen Smith
    September 5, 2013 at 9:15 pm
    Unfortunately I’m not on CC but I want to be. This sucks for me until I get it. I’m still waiting for Adobe’s answer to my “Why Should I Pay More question”: https://forums.creativecow.net/thread/378/3547#3741 Hope it comes soon.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • Peter Garaway
    September 5, 2013 at 9:29 pm
    In CS6 you cannot export a individual sequence. You export the entire project with all of its asserts. You can import your sequence into a new project and do it that way.
    I’m not a sales person so I will not comment on why you need to upgrade, however I think CC is pretty cool 😉
    Peter Garaway
    Adobe
    Premiere Pro
  • Stephen Smith
    September 5, 2013 at 9:38 pm
    Peter, I’m grateful for your help and I think CC looks awesome.
    Stephen Smith
  • Elliott Balsley
    December 13, 2013 at 1:54 am
    I have the exact same problem as the OP. I’m running Premiere CC 7.2. I’ve tried both options listed here, but it always exports one sequence, and it’s not the right sequence.
    The sequence it exports is actually used as a nest at one point in the sequence I’m trying to export.
    Elliott C. Balsley
    DIT, Colorist, Cinematographer
    http://www.llamafilm.com
  • Manny Edwards
    January 20, 2014 at 8:15 pm
    Same here. I’m on CC 7.2, and it only exports the xml for one sequence, which is nested in the sequence I’m attempting to export.
