Activity › Forums › Apple Final Cut Pro Legacy › XML Unicode problem
  • XML Unicode problem
    Posted by Stuart Bruce on November 17, 2008 at 10:53 am
    I’m using some PC software which generates XML files containing timeline information, and trying to import the XML into Final Cut Pro 6.0.4.
    I’ve got 5 XML files. Three of them work absolutely fine but for absolutely no reason I can see, two of them refuse to import, with a “critical error”.
    When I try to drag those XML files into TextEdit, I get an error “The document ep02_fcp.xml could not be opened. Text encoding Unicode (UTF-8) is not applicable.”
    However when I load the XML files into TextPad on a PC, all 5 open with no problems, so I can’t see why these 2 would be ‘not Unicode’ when to my eyes they definitely are.
    Has anyone else had this problem or could somebody point me in the right direction?
    Stuart Bruce replied 17 years, 10 months ago 2 Members · 2 Replies
  • Bjørn Holmgren
    November 17, 2008 at 9:24 pm
    The problem is probably either the encoding or the line endings. Windows uses CRLF, Classic Mac uses CR and unix uses LF. Get yourself a better text editor for your mac (TextWrangler, Smultron and SubEthaEdit are all good), open the files and save them as Unicode (UTF-8) and with Unix line endings.
  • Stuart Bruce
    November 18, 2008 at 12:31 pm
    Thanks. It was the program that was generating the XML that was at fault- it was declaring at the top of the XML file that it was UTF-8, then it was inserting non-UTF-8 character information in some of the captions.
