Xml translation was aborted due to critical error
I’ve been editing a two hour seminar in FCP5. We had three cameras and a scan converter. I digitzed everythin set-up my multi clips and edited away. Everything was working great to that point. I got done with my first cut of this monster and wanted to do some sweeting in Soundtrack Pro. I control clicked on my sequence and scrolled to send to multi-track session and then all the wheels fall off. I get the error message, “xml translation was aborted due to critcal error”. Any ideas what this means? Any work arounds??
Thanks for your help,
JeffP.S. System info:
Blackmagic NTSC DV Easy-setup for Capture
DV NTSC sequence preset
Dual 2.5 Power PC
FCP5
Os 10.4.1
Blackmagic Decklink SP Card
Decklink 5.0 Software
Lacie Firewire 800 PCI Card, 800 Firewire drives
