Activity Forums Apple Final Cut Pro Legacy XML Subtitles
  • Posted by Alexander Lee on March 8, 2007 at 7:56 pm
    Hello,
    I have a 90 min. foreign language documentary that has tons of subtitles. So far, my editor has been using the FCP text tool which is very time consuming. I’ve glimpsed at some options out there: Belle Nuit, XML2text, which we are playing around with. I was wondering is there a simple way to use one column in an excel spreadsheet for the subtitles, and then import? I’m assuming the subtitles would be then butted up against each other. Then could we adjust the clips timecode & length within FCP then reexport to another excel spreadsheet that would then include the timecode & length in other columns? I’ve tried Filemaker Pro to no avail. I’ve also checked out this link for info:
    https://developer.apple.com/appleapplications/fcpxml.html
    Any info to make XML subtitling simpler would be most appreciated!
    Alexander
    Bouke Vahl replied 19 years, 6 months ago 6 Members · 6 Replies
  • Chris Borjis
    March 8, 2007 at 8:01 pm
    another thought might be doing the sub-titles in dvd studio pro, or just editing to a digibeta tape and having closed captioning done.
    it might be more cost effective that way….my 002 cents
  • Alexander Lee
    March 8, 2007 at 8:17 pm
    I should clarify that we need the subtitles for our working cut, and since it’s a doc the subtitles do change constantly. The final subtitles for the film might be done with DVDSP. Thanks.
  • Andy Mees
    March 9, 2007 at 11:20 am
    very simple if you have some basic programming knowledge:
    all you’re doing, potentially, is reading in a tab delimited file, and placing the contents into predefined text generator containers, and saving that back out.
    if you ave a basic understanding of applescript (or can use google and are willing to learn) then theres nothing very special about doing this.
    the fcp xml manual is here: [developer.apple.com]
    there is all you need to know about reading and writing text file’s and using delimiters here: [www.macscripter.net]
    there, now you don’t even need google!
  • David Bogie
    March 9, 2007 at 3:16 pm
    You may already know this stuff. Additional reference material about captioning.
    https://www.captionmax.com/faqTechProb.php
    https://www.ccaption.com/nccwork.shtml
    https://www.robson.org/capfaq/
    bogiesan
  • Zeitanker
    March 10, 2007 at 11:36 am
    You might want to take a look at “Annotation Edit”.
    Any subtitle edit you apply in Final Cut Pro, DVD Studio Pro or Annotation Edit can be exchanged.
    So changes can be done at any state of the workflow and can be reused in any application.
    Even MS Excel XML is being imported.
    timebased metadata
  • Bouke Vahl
    March 10, 2007 at 12:30 pm
    And of course,
    https://www.videotoolshed.com/?page=products&pID=12
    Very fast subtitle prep tool, with XML support and way better text generator than the ones build into FCP. ( see https://www.videotoolshed.com/?page=products&pID=17 )
    Also look at Spherico for more options
    https://www.spherico.de/filmtools/
    hth
    Bouke
    http://www.videoToolShed.com
    smart tools for video pro’s
