Activity › Forums › Adobe Premiere Pro › XML Sidecar file
  • XML Sidecar file
    Posted by Will Downing on May 10, 2016 at 12:10 am
    Trying to submit an MXF with sidecar XML to an upload center but it keeps being rejected as the following information is missing –
    Descriptive Data Track
    Audio Track Layout
    EBU R 48: 2a
    EBU R 123: 4b
    EBU R 123: 4c
    EBU R 123: 16c
    EBU R 123: 16d
    EBU R 123: 16f
    Active Format Descriptor
    9
    10
    14
    How do I add this information?
    W
    Mark Thompson replied 10 years, 4 months ago 2 Members · 1 Reply
  • Mark Thompson
    May 10, 2016 at 4:30 pm
    Will,
    not that this will help you much but … the quick answer is to find a post house that deals with that upload center.
    With time to spare there may be another possibility. Firstly; the fails you are getting are the technical detection that some metadata is missing. They [the upload facility] ought to have a higher level document that describes their expectations. For example something like DPP AS11. Should that be the case then Adobe Media Encoder has a preset that will add that metadata. If the requirement is close then it may be possible to coax AME to produce it. I think there is an open source tool that is floating around as well.
    The best place to start is getting hold of the submission standard document and then perhaps people will have more suggestions for you.
