Activity Forums Apple Final Cut Pro Legacy XML saves time on title changes
  • XML saves time on title changes
    Posted by Steven Gonzales on November 17, 2007 at 1:24 pm
    I had to change the font and size, origin and leading of hundreds of text generator subtitles within a sequence.
    I had a sequence with the correct styles, and another with the incorrect styles.
    I exported XML’s of each, then I searched within a text editor (I like Textwrangler) to find the content of one of the subtitles.
    I compared the appropriate tags of the two XML files, then used global search and replace to change all the subtitles in the incorrectly styled sequence.
    I reimported the altered XML, and all were changed correctly.
    So I pass this along to say you can save hours by altering an XML file, and you don’t have to be a programming wizard to reap the benefits.
    Filip replied 18 years, 10 months ago 2 Members · 3 Replies
  • Filip
    November 20, 2007 at 1:46 pm
    hello there,
    can you bemore precise how to search for certain txt – i mean where is info about text size hidden – any tags connected with it etc. thank you,
    filip kovcin
  • Steven Gonzales
    November 22, 2007 at 9:29 pm
    For example, the title has “afternoon” as part of the text. I opened the XML in a text editor, and searched on “afternoon”.
    The text was enclosed is a tag such as this:
    str Text
    Afternoon
    So the string connected with this title is Afternoon. Right below that, tne next parameter was fontname.
    fontname Font
    Lucida Grande
    So if I want to change this to helvetica, I’ll just copy this whole parameter and paste it in what to search “for”.
    Then I’ll paste it again in what to replace “with”. I’ll change the Lucida Grande to Helvetica.
    And I’ll continue with any other parameters I wish to change.
  • Filip
    November 23, 2007 at 8:12 am
    thank you steven for this info. in the mean time – i was able to find it myself, but anyhow thak you for kind answer!
    all the best,
    filip
