Activity Forums DaVinci Resolve XML Question
  • XML Question
    Posted by Gina Sarentino on June 29, 2014 at 12:44 am
    Hi everyone,
    I want to know one simple question, I believe I know the answer but want to confirm it. When I have a sequence in Premiere and I have footage which has been scaled to fit the sequence resolution, and I export an XML of that sequence, in Resolve will I have the scaled footage or the Original untouched footage with it just the in and out points added. Any help will be appreciated thanks.
    Gina Sarentino replied 12 years, 2 months ago 2 Members · 2 Replies
  • Jordan Mena
    June 30, 2014 at 9:32 am
    The XML will ask you if you want to retain the scaled info or ignore it on import.
    Jordan Mena | Editor | Colorist | Producer
    Los Angeles, CA
    jordanmena.com
  • Gina Sarentino
    July 3, 2014 at 8:08 am
    Thanks for the reply, I just have one more question. Which way would you do it? Edit it in premiere in it native resolution, bring it to resolve and color correct it, and then back to resolve and changes its resolution or vice versa?
