XML problems
Shot some stuff on Panasonic P2 at 1080 24 and did a rough cut in Premiere 5.5 using the native footage in a 1080i dvcpro 23.98 sequence. then exported and XML for Final Cut. in Final Cut however I tried to relink to transcoded footage and found there was a problem with the rate. the XML from premiere is a 23.98 seq and the footage I transcoded is 29.97. tried doing a rev telecine to make it 23.98 and Im still having issues. any idea on the proper workflow for this? cant figure it out.
