Activity Forums DaVinci Resolve xml output
  • xml output
    Posted by Darren Coombes on May 28, 2014 at 7:21 am
    I am rendering a resolve 10 project back to “final cut pro XML round trip” and it keeps outputting a .fcpxml file, not a .xml file which I can’t seem to read back into final cut pro 7. Any ideas why?
    Sarah Jones replied 12 years, 3 months ago 3 Members · 2 Replies
  • Joseph Owens
    May 28, 2014 at 3:25 pm
    You’re exporting an FCP-Ten (X) XML.
    It should be exporting a: YourProject Name (Resolve).xml file which is 7 compatible. Don’t know at this point whether you are round tripping or pushing a timeline created in Resolve Ten.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Sarah Jones
    May 28, 2014 at 6:56 pm
    When you choose one of the “Final Cut Pro” Easy Setups in the current Resolve 10, the resulting XML will be a .fcpxml used in FCP X. You can achieve a .xml file by choosing “None” in your Easy Setups and manually selecting your desired Output options. After the render finishes, navigate to the Edit page and choose File > Export AAF/XML. This will open a dialog where you can choose your file name and location and also choose the type of file you wish to export. The current options as of this post include: *.aaf, *.xml, *.fcpxml (1.2), *.fcpxml (1.3), and *.edl.
    This is also discussed in the current Resolve manual in Chapter 11 “Exporting Timelines to Other Applications.”
    Regards,
    Sarah
    Support Representative
    Blackmagic Design Inc.
