Xml into After effects + changes afterwards workflow
i´m working on a project, where i got the footage and the .xml from a Final Cut Pro Timeline.
I imported the Clips into After effects, which worked fine.I know there will be some (minor) changes with the edit, so i´m wondering if there´s a way i can start working on the Clips in After Effects and then update the projcect with the finished .xml without loosing my effects and all the things i did within After Effects.
Any smart solution to this?
I know it would make sense to wait for picture lock, but as always, this seems to be wishful thinking 😉
Thank you
