Activity Forums Apple Final Cut Pro Legacy XML import to FCP 6 “General Error”
  • XML import to FCP 6 “General Error”
    Posted by Brian Tetamore on February 3, 2011 at 11:28 pm
    I’m transferring a project from FCP 7 to FCP 6 using XML. When exporting I select Interchange format Version 4. When importing into FCP 6, it gives me the initial option screen of IMPORT XML options .I leave them default. Then it asks me to save the new project. Then it begins importing, but then I get two error messages. ERROR: Critical errors aborted the processing of document. I can view the log, and then a “General Error” message comes up. THe project comes up totally empty.
    Am I missing something? Is this a bug? Any other work around?
    The Visual Rabbi
    TheVisualChurch.com
    “Crafting Visual Messages to Engage and Persuade”
    Brian Tetamore replied 15 years, 7 months ago 2 Members · 2 Replies
  • Chris Tompkins
    February 4, 2011 at 1:57 pm
    I just tried this with Exporting XML V.4 also.
    Brought it back in new Proj. (FCP7though) Worked fine.
    Maybe trying Exporting V.2, Have you tried that?
    Chris Tompkins
    Video Atlanta LLC
  • Brian Tetamore
    February 5, 2011 at 12:55 am
    Actually, I’ve done a few XML transports, even recently with FCP7 to FCP6. I’m wondering if there is something to the footage or media referenced in the project, or maybe there’s a plugin that is causing an issue.
    The Visual Rabbi
    TheVisualChurch.com
