Activity Forums Adobe Premiere Pro XML import on PC from FCP7 broken
  • XML import on PC from FCP7 broken
    Posted by Anhtu Vu on October 13, 2012 at 5:14 pm
    I tried to import an XML from a FCP7 sequence with Premiere CS6 on a windows machine, i end up with no sound even though the audio tracks are there and i see the waveform. The sequence on FCP7 is super simple, one track of video and audio.
    This same operation via CS6 on a Mac works fine. Any idea ??? thx
    Gus Evangelista replied 13 years, 11 months ago 4 Members · 3 Replies
  • Gabriel Sanchez
    October 14, 2012 at 12:22 pm
    It could be some kind of missing audio codec in the pc or out-of-date sound card drivers.
    Try Sherlock to see if you have any broken or missing codec (https://www.freewaregeeks.com/?page=detail&get_id=20&category=36) and check your audio drivers update.
  • Peter Garaway
    October 15, 2012 at 9:53 pm
    Hi Anhtu,
    Yes this is a known issue. For the workarounds
    From FCP:
    Keyframe the audio in FCP and it will retain the audio levels when opened in Premiere.
    From Premiere:
    The audio is set to -infinity on import so you will have to manually adjust the audio there.
    Hope this is helpful,
    Peter Garaway
    Adobe, Premiere Pro QE
  • Gus Evangelista
    October 18, 2012 at 3:51 am
    Yep, we occasionally get this problem even going in to Mac PPro CS6. Just highlight your audio clips in the timeline, rt-click, remove effects.
