Activity Forums Apple Final Cut Pro Legacy XML import issue: unsupported audio filter?
  • XML import issue: unsupported audio filter?
    Posted by Tony Ingrassia on February 11, 2011 at 10:25 pm
    I had an outside editor help me with a recent project. He’s working in FCP 7, I’m still on the older FCP 6.
    He exported his FCP 7 project as an XML 4 (he also gave me other XML versions, but my understanding is that to go from 7 to 6, you need an XML4).
    Every time I try to open the XML 4, FCP 6 hangs at about 78%. The project contains green screen video that was keyed using Conduit, with several effects, so I need to be able to check the “Include Audio/Video Effects” option in the Import XML window.
    When I import the XML 4 into FCP6, with all options unchecked (no reconnecting to media, no markers, and no audio/video effects), the project opens, but all the timelines are screwed up (no keys, text in wrong places, etc…), and it gives me the “Non-critical Errors” dialogue box. When I select “Yes” to see the list of errors, it’s the same error, over and over again:
    : Unsupported at scope.( line 22620 )
    …with only the last number (in the above example, 22620) being different on every line.
    I’m assuming that this error is what’s causing the import hang when I import with Audio/Video Effects.
    I’ve tried trashing preferences, I’ve tried deleting (or moving) the Plugins folder, all to no avail.
    Look familiar to anyone?
    Tony Ingrassia replied 15 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
