Activity › Forums › DaVinci Resolve › XML import is not reading Timecode
  • XML import is not reading Timecode
    Posted by William Edwards on March 15, 2013 at 6:33 pm
    Hello,
    Working from FCP 7 XML Version 5, importing to Resolve 9.0.4…
    There is a conflict with timecode timeline clips, wherein if I have one clip in my sequence that’s used multiple times, the in and out points of the timecode are not being read properly. So while the first time the clip is being used is correct, every time proceeding that is off.
    Is there a conflict with versions here? Why isn’t Resolve just reading the timecode of the clip itself as it lays on the timeline?
    EDIT: These were from MULTICAM edits, but I committed the multicam. Is it still reading the timcode from another clip even though I committed?
    Eric Johnson replied 13 years, 6 months ago 3 Members · 3 Replies
  • Joseph Owens
    March 15, 2013 at 8:33 pm
    Multicams were something that Apple never really figured out even when they were in control of both FCP and COLOR. Essentially it behaves similarly to an imbedded sequence, which are verboten. Even when you “commit” a Multicam, its still a multicam– if you can still “open” it, that means there are going to be ambiguous source references in the XML.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • William Edwards
    March 15, 2013 at 9:01 pm
    That’s pretty poor… and kind of hillarious. Did they fix it in recent FCP versions? Do you know if that’s a problem with Adobe’s Premier?
  • Eric Johnson
    March 15, 2013 at 9:12 pm
    after committing the multi cam edits, you could media manage “using existing” and make sure the “multi-cam” check box at the bottom is unchecked(?), pretty sure… that should strip out the multicam-ness…
