Activity › Forums › DaVinci Resolve › Xml from Davinci resolve 9 lite to Pp 6
  • Xml from Davinci resolve 9 lite to Pp 6
    Posted by Thomas Ko on May 13, 2013 at 3:01 am
    Hello,
    I was trying to import xml file from davinci resolve 9 to premiere pro 6 and it gives me this error.
    – THIS PROJECT CONTAINS A SEQUENCE THAT CANNOT BE OPENED. NO SEQUENCE PRESET FILE OR CODEC COULD BE ASSOCIATED WITH THIS SEQUENCE TYPE.
    From resolve, I chose easy setup with Final Cut xml and rendered everything. I have no problem importing the xml to final cut pro. It’s first time using resolve and it’s pretty tricky.
    Thank you guys!
    Tom
    Thomas Ko replied 13 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
