Activity Forums Apple Final Cut Pro Legacy xml export to AE import
  • xml export to AE import
    Posted by Subspecies on April 26, 2007 at 5:13 pm
    hi all,
    i’m trying to export a sequence from FCP via the xml export function. All is good, but when i try and import into AE it won’t let me…any idea how to do this?
    do i need to buy the Automatic Duck importer?
    any help is appreciated
    Andy Mees replied 19 years, 5 months ago 2 Members · 1 Reply
  • Andy Mees
    April 26, 2007 at 5:23 pm
    the FCP XML Export will create an XML with a specific structure used by FCP for describing the sequence … unless AE now understands that structure then yes, you need a third party solution such as Automatic Duck to translate your sequence data into a format that AE can understand
