Activity Forums Adobe Premiere Pro XML Export Error
  • XML Export Error
    Posted by Brett Putman on February 27, 2013 at 3:23 am
    I’m using Premiere Pro CS6 on OS X and I have some audio that I need to sync using Pluraleyes. I go through the usual steps of exporting an XML for Pluraleyes to see, but right after exporting I get an error message. I then try to sync using Pluraleyes and Pluraleyes sees the XML just fine, but when it attempts a sync, it also gives me an error. I have attached a couple of screen grabs to show what error messages I am getting.
    The problem seems to be a simple text title that I made in Premiere called “Realness and Humanity” (which you can see in the error report in the second image), but I have tried creating saving as a different project file and then deleting that title all together and still I get the error.
    Anybody ever had this issue?
    Andrew James replied 13 years, 6 months ago 3 Members · 3 Replies
