Activity Forums Adobe After Effects Expressions XML excel spreadsheet – access text in cells.
  • XML excel spreadsheet – access text in cells.
    Posted by Fabio Apelbaum on May 23, 2016 at 4:29 pm
    Hi guys!
    Im trying to use an excel spreadsheet (XML) to change text layers In my after effects project, I was looking at the code inside the excel spreadsheet XML I have and this text that I am trying to access seems to be inside namespaces, such as in this sample: Data ss:Type=’String’>original text /Data. is there a way to retrieve “original text”?
    Please find some of the code I have so far in the image attached, I included the xml inside my code just to test it, later I will write my script to gather the XML info from an XML Excel file.
    This is what the XML file looks like:
    And this is so far, the code that I was able to put together, it just does not do what I need yet….
    Thank you all in advance!!
    Fabio Apelbaum replied 10 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
