Activity Forums DaVinci Resolve XML Crashes
  • XML Crashes
    Posted by John Christoforu on January 19, 2012 at 7:49 am
    Good morning to all of you, I’ve been trying to import an XML to resolve lite with no luck.
    I click add an XML and I’m asked to located the materials, the I click on the source disc and
    crashes. Any thoughts?
    MacPro late 2009, Nvidia GT 120 – 512MB
    OS X Lion 10.7.2
    14GB RAM
    CUDA driver version 4.0.50
    John Christoforu replied 14 years, 8 months ago 2 Members · 2 Replies
  • Peter Chamberlain
    January 20, 2012 at 12:56 am
    Hi, from your equipment list it seems you do not have an image processing GPU, like a Quadro 4000. If this is the case, the GT120 is being used for UI and processing and its running our of resources when you load the xml.
    Please refer to the configuration guide at the BMD support web site for certified hardware configs.
    Peter
  • John Christoforu
    January 20, 2012 at 7:10 am
    Thank you Peter for answering my Q. Had a feeling that would be probably the luck of GPU.
    just for the record, I think is a bit odd to go as far color correcting raw material and by
    the time I’m about to add material from the XML list for the final grading resolve crashes.
    Anyway thank you for getting back!
    John
