Activity Forums Apple Final Cut Pro Legacy XML between FCP6 and FCP5
  • XML between FCP6 and FCP5
    Posted by Scott on June 19, 2008 at 6:41 am
    Has anyone been able to use XML to open projects between two different versions of FCP?
    Specifically FCP6 and FCP5?
    I need to do simple sound sync only on FCP6 that needs to be opened on FCP5. No fancy effects or anything, just lining up clips.
    Am I understanding correctly what can be done with XML? Is this possible? Is it reliable for a production workflow?
    Scott
    Andy Mees replied 18 years, 3 months ago 3 Members · 2 Replies
  • Shane Ross
    June 19, 2008 at 7:17 am
    [Scott Wright] “Has anyone been able to use XML to open projects between two different versions of FCP?
    Specifically FCP6 and FCP5?”
    Yup. Between 6.0.2 and 5.1.4. Zero problems.
    [Scott Wright] “Am I understanding correctly what can be done with XML? Is this possible? Is it reliable for a production workflow?”
    Yes. Yes. Yes.
    #46 – Supported XML versions
    Shane’s Stock Answer #46 – Final Cut Pro and versions of XML it supports
    FCP4 supports XML version 1 only
    FCP5 supports XML versions 1 and 2
    FCP5.1 supports XML versions 1, 2 and 3
    FCP6 supports XML versions 1, 2, 3 and 4
    Shane
  • Andy Mees
    June 19, 2008 at 7:49 am
    just going back to sleep here … move along
