Activity Forums Maxon Cinema 4D Xmas lights Xpresso rig – lights not showing up in render!
  • Xmas lights Xpresso rig – lights not showing up in render!
    Posted by Luis Flyp on November 6, 2020 at 3:46 pm
    Hello there, hope this message finds you well.
    Many times I’ve ended up in this forum while searching for solutions for my C4D problems, but now I’ve come up with a specific situation that I can’t seem to solve and so I’ve decided to give it a go and post a question for the first time here.
    I have purchased the following xmas lights simple xpresso rig but for some reason beyond my comprehension the lights just don’t show up in the final render. The render settings are set to Physical at the moment but the end result would be to convert it to Vray, which I believe I can do… As soon as I understand why the light don’t show up. Can someone help me out with this?
    Thank you in advance for your time and attention.
    Jim Scott replied 5 years, 9 months ago 2 Members · 2 Replies
  • Jim Scott
    November 6, 2020 at 9:50 pm
    Changing the light sources Visible Light setting to “Visible,” and using the Standard renderer, I got the image below. Is this more of what you’re looking for?
  • Jim Scott
    November 10, 2020 at 2:34 pm
    I guess finding a solution wasn’t that important.
