Activity Forums Panasonic Cameras xlr input problems
  • xlr input problems
    Posted by Luke Pearson on August 14, 2009 at 4:06 pm
    I have an hpx170. My ch 2 xlr is giving me problems. Sounds like its a bad connection. It sounds static. Sometimes it goes away if I wiggle it around. Has anyone had problems with this? Does the input just need cleaning? Thanks for any help!
    Luke Pearson
    http://www.LiftFilms.net
    Do not forget to entertain strangers, for by so doing some have unwittingly entertained angels.
    -Hebrews 13:2
    Luke Pearson replied 17 years, 1 month ago 2 Members · 2 Replies
  • John Fishback
    August 14, 2009 at 6:59 pm
    Check the connection with another cable. If you still have the static, it’s in the cam. It’s possible the connection is dirty. You can try using compressed air in a can to blow out the connector. If there’s still static then you need to get it serviced. If the static goes away when you switch cables, then the first cable is bad.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Luke Pearson
    August 14, 2009 at 10:12 pm
    Sorry I forgot to mention it does it with all cables. Its been doing this for a while. I know panni will make this right.
    Luke Pearson
    -Hebrews 13:2
