Activity Forums Apple Final Cut Pro Legacy XLH1 and Audio Sync
  • XLH1 and Audio Sync
    Posted by Virge Castillo on April 12, 2006 at 1:56 pm
    Hi all,
    Checking to see if anyone has come across a problem a client of mine is having. He is capturing footage shot 24F from a Canon XLH1 (via HD-SDI/with analog audio thru a Kona LH) to FCP 5.0.4. The audio and video are out of sync by 2 frames. Any ideas would be most welcome.
    Virge
    Mbboehm replied 20 years ago 3 Members · 5 Replies
  • Virge Castillo
    April 12, 2006 at 1:58 pm
    He is capturing HD-SDI to the DVCPRO HD codec. In case that makes a difference.
  • Michael Gissing
    April 13, 2006 at 1:10 am
    Is audio ahead or behind? If ahead, then an in line delay is possible. Otherwise resync the clips after capture by slipping audio. I have had a similar issue capturing off a Pro 110HD Panasonic deck. The editor slipped sync and then (I think) made sub clips after.
  • Michael Gissing
    April 13, 2006 at 1:11 am
    typo – a Pro100HD Panasonic deck (via HDSDI pic & sound embedded)
  • Virge Castillo
    April 17, 2006 at 6:37 pm
    The audio is ahead of the video, again by 2 frames.
  • Mbboehm
    September 7, 2006 at 5:23 pm
    We are also having audio sync issues trying to use our Canon XL H1 camera with our FCPs. From camera, we use Convergent Design LE box, and take firewire to RSS for deck control with FCP. The SDI signal from the Convergent Box then has the audio imbedded and that goes thru our KONA2 K-box into FCP into a sequence set for DVCPRO HD or sometimes 1080i uncompressed. Is there any way to correct for the audio sync issue without having to slip the audio in the timeline?
