Activity Forums Canon Cameras XL2 tape issue with Sony DSR-11
  • XL2 tape issue with Sony DSR-11
    Posted by Brian Wittman on May 10, 2005 at 8:57 pm
    When viewing and capturing Sony Premium miniDV tape shot with Canon XL2 camera – looks terrific. When using Sony DSR-11 deck to view and capture I get pixelation “pixie dust” through the footage. When using another tape (Panasonic) everything seems OK. A friend of mine suggested it was the tape’s emulsion and that a roll through the heads should clear it up. It hasn’t. Note: all things out of box new so wear is not the issue. Any ideas? HELP!!!
    Don Greening replied 21 years, 3 months ago 3 Members · 3 Replies
  • David Jones
    May 10, 2005 at 10:41 pm
    Sony is a wet style tape,
    Panasonic tape is manufactured by Fuji which is a dry style.
    Try cleaning the heads and see if it will play OK.
  • Brian Wittman
    May 10, 2005 at 11:01 pm
    tried that – still ng. Thanks for your reply… any other ideas. Perhaps just use dry-type tapes and dupe the Sony tapes to dry media?
  • Don Greening
    May 11, 2005 at 4:34 am
    Brian,
    I would assume that Sony Mini DV tapes would be compatible with their own decks. Sounds like it may be a tracking problem on that one Sony tape. Try recording some test footage on another Sony tape and go through the workpath process again and see if the problems go away or are duplicated. In the meantime, since you stated the sony tape will play back fine with the XL2 you can use your camera as a deck and get your footage on to your computer via firewire OR put a new tape in the DSR-11 and hook the XL2 to that for the transfer.
    – Don
