Activity Forums Canon Cameras XL2 free run time code & multi-cam shoots
  • XL2 free run time code & multi-cam shoots
    Posted by Lawrence Mcdonough on July 31, 2006 at 7:23 am
    Anyone out there finding issues in your NLE system while batch capturing from tape (s) using the free run time code on your XL2? I use FCP 5 and am capturing from a multi-cam shoot where two cameras were on free run time code ( set properly before the start of shooting ) and I am noticing some slight out of sync in the time codes between tapes. Also batch capturing seems to drive my NLE nuts when it spots a time code break, sometimes it will not capture the batch at all or just a few clips giving me a “time code error” message
    Larry
    Donald Berube replied 20 years, 1 month ago 2 Members · 1 Reply
  • Donald Berube
    August 10, 2006 at 5:44 am
    Don’t use Free Run unless you will not be pausing during recording – and that is very rare.
    If you need to identify time of day, then set time of day with the User Bits on the XL2.
    By using Rec Run, you will reduce the incidence of time code breaks – or changes in timcode if you pause a lot during recording.
    – don
    https://noisybrain.com
    https://www.bosfcpug.org
    https://fcpugnetwork.org
