Activity Forums Canon Cameras XL2 Audio
  • Bouncing Account needs new email address
    November 16, 2005 at 4:13 am
    [Kellie B] “can I take audio from the from and back simultaneously or only two from the back XLRs?”
    I assume you mean “front and back”.
    What are you trying to “take it” into?
    Or do you mean record ONTO (into) the camcorder?
    November 16, 2005 at 11:07 am
    You can record to tape from all four inputs at once.
    The record mode must be in 32 KHz/12 bit to record each input independently to its own track.
    The on-camera mic (or optional external mic[s]) can be used in the “front” and other source[s] (mic[s] or mixer[s]) can be recorded in the “back”.
    During editing, you will be able to send these all out independently to the edit system.
