Activity Forums Canon Cameras XL1 lens alert flashing
  • XL1 lens alert flashing
    Posted by Craig Lindvahl on October 19, 2005 at 2:18 pm
    Hello-
    We have several Xl1 and XL1s cameras in our class. One of our Xl1 cameras has the “check the lens” alert flashing. According to the manual, the camera is not recognizing the lens.
    I switched the lens to another XL1, and the lens worked fine, and the problem camera gave me the same message with a different lens attached.
    Any ideas?
    Thanks very much.
    Craig Lindvahl
    Peter Ralph replied 20 years, 11 months ago 3 Members · 3 Replies
  • Don Greening
    October 19, 2005 at 3:25 pm
    You might try having a look at the electrical connections on the camera body where the lens attaches. I seem to remember someone having a similar problem and they found dirt/dust/grease residue on those contacts. If that doesn’t solve the problem then you may have to take it in for service.
    – Don
  • Craig Lindvahl
    October 20, 2005 at 12:40 pm
    I cleaned the posts, but no luck. I think I’ll probably have to send it back in to Canon. I imagine it’s due for servicing anyway.
    Thanks a lot
    Craig L
  • Peter Ralph
    October 25, 2005 at 3:13 pm
    not just the posts you need to clean the entire mating surface. a pencil eraser rubbed very carefully over the surface might help , if you feel confident about not introduing any residue into the camera
