Activity › Forums › Canon Cameras › XL1 and microwave link chroma drop out problem
Posted by Scott Boyd on June 19, 2005 at 7:45 amHi , has anyone got some ideas,
I have just tried to send some footage to a TV network over a microwave link but when it was being recived the chroma chanel was missing ( ie no color the footage was in B/W)
any ideas?Bouncing Account needs new email address replied 21 years, 2 months ago 3 Members · 5 Replies -
David Jones
June 20, 2005 at 12:59 pmHow do you have the video signal connected to the microwave input?
Scott Boyd
June 23, 2005 at 1:06 pmI use the Video terminal and rca jacks,
Im not sure what part of the process is causing the probs but it could be one of 3 things the camera, somthing to do with the microwave link or the or the the recording process at the tv station -
Scott Boyd
June 26, 2005 at 10:07 amthis was my first step, to try and find out if any one elce had a problem and get some ideas
June 27, 2005 at 4:13 pmMaybe I can cut this single question/single answer thing down a bit.
There is nothing special or unique about the composite output of an XL1.
Next time, send the camera’s composite output to a professional color monitor and “LOOP” the monitor’s output to the microwave. (Turn OFF the 75 ohm termination of the monitor, if it has a switch).
If you are seeing chroma and video from the camera’s output on the monitor, the microwave should have no trouble sending the full signal.
If there’s still a problem, I’d suspect the microwave unit.
They are supposed to sync to incoming video and just “pass it through” to the receiving link.
