Activity Forums Blackmagic Design XL-H1 using a Multibridge Eclipse
  • XL-H1 using a Multibridge Eclipse
    Posted by Micah Wolf on November 5, 2008 at 11:15 pm
    We know that the XL-H1 does not have embeded audio in its HD-SDI port, but if you capture using the multibridge eclipse using the cameras SDI port and also use the cameras balanced XLR outputs to the eclipse can you link up the audio in Preimer Pro?
    I am researching getting a new XL-H1 and eclipse for a new editing suite and just trying to figure out if this could work.
    Further more could you use a canon HV-20 and its HDMI output to capture the audio and video using the eclipse?
    Any feed back would be great. Thank You
    Chris Pearse replied 17 years, 10 months ago 2 Members · 1 Reply
  • Chris Pearse
    November 11, 2008 at 10:04 am
    Hi Micah,
    Inputting SDI video and XLR audio into the Multibridge Eclipse is no problem. The settings menu for the Eclipse allows you to select whether you want to use the embedded audio or analog audio, on both SDI and HDMI. This then becomes the audio source that Premiere Pro will use for capture.
    Chris Pearse
    Technical Support Consultant
    Blackmagic Design EMEA
