Activity › Forums › Canon Cameras › xl h1 capture from settings.
  • xl h1 capture from settings.
    Posted by Delano Bryant on August 20, 2007 at 2:48 pm
    I am trying to capture footage shot on the xl h1. I use fcp6, i am connected via firewire. I set the camera to VCR mode. I went into system menus and PLAYBACK STD… is blacked out. I can’t seem to get the camera to talk too FCP. I can see my footage in the view-finder on the camera. So i know its there… HELP
    William Busby replied 19 years, 1 month ago 2 Members · 3 Replies
  • William Busby
    August 22, 2007 at 5:10 am
    disconnect the firewire cable before making changes in the menue, then re-connect firewire.
    Bill
  • Delano Bryant
    August 22, 2007 at 3:21 pm
    Bill thank you. what settings do you set in the menu for capture?
    Is that the color red you want to use?
  • William Busby
    August 22, 2007 at 3:55 pm
    I don’t own a XLH1, but I have a XHA1 & assume it’s the same or quite similar… On the A1 for playback standard it should be HDV if you’re capturing HDV.
    Bill
