Activity Forums Canon Cameras XH-A1 & Final Cut
  • XH-A1 & Final Cut
    Posted by S2videos on March 25, 2007 at 6:12 am
    I recently purchased the XH-A1 and am capturing via firewire to Final Cut. I have successfully captured DV and 16:9 DV. Every time I try to capture HDV I either get an error or I have deck (camera) control but when I try to capture the tape rolls for the duration of the clip but nothing captures and I have to abort. I am trying to capture HDV 60i.
    Seems like there are two places I may be using the wrong settings, Easy set up and the capture settings in the capture window.
    Also, the Preview window is always disabled while I am trying to capture HDV.
    Thanks in advance for your help!
    Brad Holland replied 19 years, 5 months ago 2 Members · 1 Reply
  • Brad Holland
    March 27, 2007 at 1:18 pm
    I have a similar problem with the preview window being disabled while I capture from my Optura. I just close FCP, shut down the machine, unplug the power cable and wait about ten seconds. Then I reconnect everything, start back up and try again. It always works fine then. It might be something between FCP and Canon cameras…Can’t explain it, but it works for me…
